Orientation of oil pick up tube
Old May 14, 2004 | 02:17 PM
Red96Lt1's Avatar
I'm at work and I have acces to a machine shop, and I was wanting them to put a tac weld on my pick up tube so I don't have to worry about it. I was wondering what the orientation of the tube was. I assume the screen is perpendicular to the shaft. Can anyone confirm this. Thanks.
Old May 14, 2004 | 02:33 PM
My Red 93Z-28's Avatar
correct
perpendicular to the shaft, parallel to the bottom of the pump.
Old May 14, 2004 | 02:52 PM
Red96Lt1's Avatar
Thank you very much.
Old May 14, 2004 | 04:25 PM
No problem
Old May 14, 2004 | 05:26 PM
Mine was angled down farther than perpendicular. ~5¼" from the mounting surface of the pump to the lowest part of the pick-up.
Old May 15, 2004 | 08:27 AM
Eff's Avatar
Eff
I went ti have a shop weld mine last week and they said " welding is no way to do it, we will pin it for ya"
I dont see a benefit to "pinning" what are your thoughts?
Old May 15, 2004 | 10:30 AM
1996 | Z28 SS's Avatar
This is what I did for the oil pump on the 355 I built..
I didn't weld the pick up tube directly.. what I did was got some sheet metal, cut it into a trianglular shape. At at two corners of it, drilled holes so they match with the bolt threads in the body of the pump (sorry.. I don't know the technical names..) You bolt down the sheet metal inbetween the bolt head and the body so that it secure, then bend the piece a bit and weld the third corner to the pickup.
I know that sounds like a lot of work.. but if you ever need to get your pick up tube off later.. it's not welded. And at the same time it's completely secured.
Old May 15, 2004 | 01:32 PM
Serene's Avatar
I find welding the tubes makes them brittle and they can break, so I tie the pickup on with wire. No way for it to come off and its still removable if needed
HectorM52
Jul 30, 2017 11:46 AM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
