Optispark wire harness problem
Old Mar 26, 2004 | 09:06 PM
ru2slo_99's Avatar
I just got all the parts from Jason Cromer to switch to a vented opti. I went to plug in the new harness into the main wiring harness and it would not plug up. I looked and the opti plug has two rails on the inside and the the cars plug has only one groove. I am thinking about grinding the one rail down so it will fit. I was just wondering what everybody else is doing, if anybody else has had this problem?
Old Mar 26, 2004 | 09:21 PM
If you are referring to the plug on the side of the intake, just modify it. That's what most people do.
Old Mar 26, 2004 | 11:23 PM
ru2slo_99's Avatar
That would be the one.
Old Mar 26, 2004 | 11:26 PM
96SS232's Avatar
had the same problem when my harness fried on my car. Instead of hacking up the harness, just use a paper clip, remove the wires from the plastic harness, and snap the new wires back into your old connector. Its simple and professional.
Old Mar 26, 2004 | 11:30 PM
Even better.
Old Mar 26, 2004 | 11:39 PM
Max 93's Avatar
three swipes with a hack saw blade was enough the make mine work.
Old Mar 28, 2004 | 02:55 PM
ru2slo_99's Avatar
I just used a safety knife and cut it out. It fit perfect.
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
$hawn
Aug 3, 2002 04:59 AM
CobraEatr
Jul 23, 2002 06:32 PM
