Optispark vent lines
Old Jun 17, 2009 | 09:44 PM
Bobsep84's Avatar
I think i may have had my vent lines connected reverse on my optispark. With the car on i pulled the vent hose out of the intake elbo but could not feel any vacuum on that line? However when i reversed the lines on the optispark i can now feel suction on the line that connects to the elbo. Does this mean i have it connected correctly now?
Old Jun 17, 2009 | 10:40 PM
They should be like this: http://shbox.com/1/opti_vacuum_harness.jpg
It should pull air from the elbow toward the intake manifold fitting.
Old Jun 17, 2009 | 11:51 PM
Bobsep84's Avatar
I was having a hard time tracing the 2 lines...i couldn't see from under the car which one went to the elbow and which one went to the manifold....if the 2 lines were reversed..it wouldn't pull any air from the elbow fitting right?
Old Jun 18, 2009 | 12:45 AM
There's a check valve in the line that is supposed to go from the Opti to the vacuum connection on the manifold. If you switch the lines, and attach the end of the line with the check valve up near the elbow, the check valve would prevent the vacuum from reaching the point where the line connects to the elbow.
Old Jun 18, 2009 | 08:34 AM
Bobsep84's Avatar
Ahhh ok, i must have it connected correctly now because before i was not getting any suction at the elbow connection but now i am. Thank you both for your help!
Old May 14, 2010 | 01:00 PM
Brangeta's Avatar
Guys, where does this line connect? I just got the car back from my mechanic and noticed the hose isn't connected to the air intake elbow. I can't find where to trace the other end to. Help!
Old May 14, 2010 | 04:42 PM
Go up 5 posts, and click on the link in Shoebox's post.
Old May 14, 2010 | 05:44 PM
brucer's Avatar
anyone one have one of these vacuum harness's for sale cheap?
Old May 14, 2010 | 05:47 PM
dangalla's Avatar
i would just make one out of some vacuum line and a check valve
Old May 14, 2010 | 07:02 PM
Brangeta's Avatar
I figured it out. The damn thing was inside the cover for the throttle cable. This mechanic isn't the perfectionist he claimed to be. 1.79 quarts low on coolant and finding crap that was left unplugged.
HectorM52
Jul 30, 2017 11:46 AM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
Dec 4, 2014 11:56 AM
Jul 4, 2005 05:00 PM
