Optispark vacuum hose to intake
Old Jul 26, 2004 | 12:02 AM
j071752's Avatar
I had my optispark off (WP R&R) and the vacuum harness got pulled off later on also. I know which hoses hook up to the opti, I know which one goes to the intake elbow. I need to know where the larger hose connects to the intake? Anybody got a pic or description of where it goes? Since it got pulled loose by mistake, I have no idea.
Old Jul 26, 2004 | 12:18 AM
Spinner's Avatar
Re: Optispark vacuum hose to intake
Goes to a bung on the driver's side of the intake, in front of the brake booster
Old Jul 26, 2004 | 09:10 AM
This might help.
Old Jul 26, 2004 | 09:27 AM
j071752's Avatar
Thanks Rob,
I am straight now, I had taken this apart way back at the end of May. MY gosh, this sucker is gonna fire up this afternoon for sure. I just realized this morning all I had to do was go look at my my 95 T/A and see exactly how things should be on the 97Z. So I checked it out this morning. How come my 95 T/A does not have a EVAP Canister Purge Soloniod Valve? I just recently got the car, prior engine swap? or did they make some early 95's w/o?
http://shbox.com/1/evap_sol.jpg
Also, my 97Z has a small hose going from the "L" in the Air Hose to the Bleed Valve Harness (96-97 only) the same "L" on the 95 T/A has nothing attached to it, is that cool or should a hose be running from it somewhere?
Old Jul 26, 2004 | 09:33 AM
There were no LT1's built without the EEC purge solenoid.
You might want to look at the diagrams on Shoebox's Tech Pages, showing the difference between the various year (93/94, 95, 96/97) for the EEC and AIR systems. There was also a recall on the 95 and newer AIR systems, and whether your car had the recall done will affect the details of the AIR plumbing.
Old Sep 13, 2004 | 12:46 PM
BAD 97 WS-6's Avatar
What if you are boosted? Do you still want to have that hose connsected to the intake? Is it ok to leave it disconnected? I won't hook it back up to the side of the intake until I know for sure its safe.
Old Sep 13, 2004 | 04:26 PM
mzgp5x's Avatar
I run low-pressure side to blower intake near scroll. This eliminates positive pressure condition on opti vent.
________
97 383/ DI 15psi
Old Sep 13, 2004 | 04:49 PM
________
97 383/ DI 15psi
Can you explain furthur. I am still a little confused.
Old Sep 14, 2004 | 10:44 PM
mzgp5x's Avatar
The 1996/ 97 year Opti has two hoses or vents. One is the suction side and the other has a series of filters. One Opti vent (or hose) is connected to the intake manifold vacuum on NA motors. On a FI app, the intake manifold will be @ positive pressure (not vacuum) under boost. Therefore, the logical vacuum source would be the intake @ the blower since this is normally always a negative pressure source. This way the opti shall always have air flow thru it to eliminate moisture and some air for cooling.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
