Optispark upgrade questions...
Old Aug 6, 2003 | 03:51 PM
Myxtreme1's Avatar
Right now I'm pretty sure my opti is bad just from looking at it. Well in shopping for a replacement I have found the exact same one is between $280 and 450 with rotor and cap. At autozone I believe they have the whole vented one for like $130!! What all do I need to do to upgrade? I know that you have to get the timing cover and cam locator pin ( i think ) but what else needs to be done. The timing cover it like $52 so I'm only up to around $180. Any info is appreciated! Thanks!!
Old Aug 6, 2003 | 04:44 PM
Vented Opti Conversion
I suspect if you check the AutoZone price, you will find it is either the cap/rotor, or the back 1/2, not the complete unit. You can get a genuine GM, completed vented Opti from Jason Cromer for $190.
Old Aug 6, 2003 | 04:53 PM
Myxtreme1's Avatar
Why is the vented one always so much cheaper??
Old Aug 6, 2003 | 05:45 PM
Brians_TA's Avatar
I dont know about anyone else but I have found when it comes to electrical parts its best to use GM parts. I got 3 ignition control moduels from AZ and none of them worked on my car they all threw codes and wouldent let it run...
Old Aug 6, 2003 | 06:21 PM
Myxtreme1's Avatar
I think I will be going with the GM Opti...
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
