Optispark Upgrade gone bad?
Old Aug 7, 2003 | 12:42 AM
raceme's Avatar
Had racing engine builder build my 383, lots of upgrade, forged, ported, 58mm tb, cam,...
Also upgraded from non vented to vented opti. Motor is back in car, motor turns over, but no spark. Everything looks like it's connected correctly. Getting power to coil, no spark from coil, coil worked with old motor.
Is it possible the Opti could be the problem? Any ideas on how to test to make sure New Opti was installed correctly?
Appreciate the help!
LT1, 383, 8lb boost via Procharger, MSD, Headers, no smog, no a/c, as&m 58mm tb, vented opti, ported heads, cam, forged bottom end, alum 13lb flywheel, 6speed.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ad356
Apr 11, 2015 11:12 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
