Optispark swap guide
Old Dec 25, 2007 | 03:15 PM
ssbowtie1's Avatar
Hey guys, I'm about to replace my opti. I've done the swap before, but it was over 3 years ago, and I wanted to look at a guide to refresh my memory and in case I forgot any tools I might need.
It seems all the old opti swap links are broken. I guess not so many people are working on lt1s anymore
Anyways, does anyone have any links that are still working?
Old Dec 25, 2007 | 03:34 PM
ricehammer's Avatar
http://www.z28.com/forum/showthread.php?t=47479
Old Dec 25, 2007 | 04:58 PM
Nah, everyone just knows what they are doing, now.
It's the same as it was before. I'm sure you will remember, once you start.
Old Dec 26, 2007 | 02:18 PM
ssbowtie1's Avatar
Thanks for the link ricehammer.
Shoebox, I hope I do remember again, I must say though many of the common problems I remember seeing on this forum daily don't seem to be asked much more. Either people really do know what they're doing or we're a dying breed
One thing I don't quite remember is if I need to use a puller puller/installer to get the crank pulley off, or if it comes off on its own. Isn't a 3 jaw puller recommended? What about for installation?
Old Dec 26, 2007 | 02:31 PM
You may or may not need a 3 jaw puller to get the pulley off. Some come off more easily than others. Installation is nothing more than bolting it on. The hub does not need to come off for an opti swap.
Old Dec 26, 2007 | 02:38 PM
The Engineer's Avatar
Some additional advice. Once you have the Opti installed and before you install the water pump/coolant and everything else, you should do a "quick start" and "very short run" to make sure you have the Opti keyed correctly with the cam. Then if it won't run, it is easy to remove and recheck the Opti.
I've never had a problem with this myself, but I've seen where "several" people here on the forum have "somehow" miss-keyed the Opti, then had to take "everything" apart again.
Good luck!
WD
Old Dec 26, 2007 | 04:14 PM
Wild1's Avatar
It is also a good time to replace the seal if it is leaking.
Old Dec 26, 2007 | 04:16 PM
Wild1's Avatar
No, I agree with shbox, you do not need to pull the crank pulley for an opti swap. Unless you are changing your timing belt? Then now is a good time since you'll have everything nearly to that point.
Old Dec 26, 2007 | 06:21 PM
Every LTX engine I've seen has a timing chain and not a timing belt!
WD
Old Dec 26, 2007 | 11:02 PM
If you are going to agree with me, you will have to agree that the hub does not need to come off. The pulley does.
Old Dec 27, 2007 | 08:54 AM
I have an "aftermarket" SFI keyed hub (round facing) and I "can not" remove the complete Opti or even the cap without pulling the crank hub.
Although, as you have pointed out with the "factory hub" (w/ three spokes), you can turn the hub to the correct position with the spokes in the right position and remove the Opti.
WD
Old Dec 27, 2007 | 09:09 AM
WD
Unless noted, I am speaking regarding stock parts. Your info regarding the SFI is good to note for those that have it.
KYWes
Jun 14, 2022 06:52 AM
Jmlcolorado
Jul 4, 2015 08:31 AM
alex5366
Jun 8, 2015 07:52 PM
KamikaZ28
May 28, 2015 12:45 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
