Optispark swap...
Optispark swap...
it's been a while, bu to prep my car for opti removal...and to remove the water pump....what do I need to remove? Drain the coolant first, remove water pump and what else?
Re: Optispark swap...
You should do the block. The coolant will still be in the waterpump. Drain either the knock sensor or the plug on the opposite side. I think the knock sensor is the easier of the 2 plugs.
If you have the airpump, you have to remove that also. I think you might need to take off the coil. I don't think you can get by with only removing the balancer. I am pretty sure you have to take the hub off also.
Z
Z
Hi guys I did my opti about a year ago and I followed the intructions on these guys web site. It is spot on with photos of every stage. Very useful.
http://www.streetillusionsracing.com...ll/install.htm
I hope they don't mind me giving them a plug on here.
