optispark problem
Old Jul 2, 2003 | 04:36 PM
m_morrison14's Avatar
optispark problem
I am replacing a bad optispark on my 96 Z28, A4. Only problem is that when I try to get the camshaft balancer off( the 3 bolts on the outside of it) it just spins and will not loosen. Anyone have a solution?
Old Jul 2, 2003 | 04:56 PM
thewinner's Avatar
are you talking about the crankshaft hub? if so, just rotate it using the center bolt, make sure car is in neutral, so that the ears arent sticking up, and you should be able to remove it
Old Jul 2, 2003 | 05:48 PM
thanx 2cntry, that worked
RUENUF
Mar 13, 2016 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
brentbrowning01
Dec 3, 2014 10:36 PM
