Optispark install problem
Old Oct 27, 2005 | 10:53 PM
Craver's Avatar
Okay guys heres what i got. Driving a 93 Trans am LT1 73k miles. Just recently replcaed cap and rotor on opti reinstalled everything and engine will rotate but not start. Ran all the wires from the spark plugs in the block to the distributor all the plugs are in the right places.Took the boots off and there is spark but still wont start. Not sure what to do next. Any ideas would be appreciated.
Old Oct 27, 2005 | 11:59 PM
Birdman7389's Avatar
Re: Optispark install problem
Double check all the plug wires.
Did you remember to plug in the main opti connector on the top passenger side?
Old Oct 28, 2005 | 12:56 AM
cammed_aro Z28's Avatar
i would also say check the main plug, make sure you got the right opti. if you got a 95 and newer vented, the hole for the plug is too deep and the connecter on the plug will not reach.
Old Oct 28, 2005 | 01:43 AM
SS RRR's Avatar
Did you have to force it on in any type of way or did it slide on easily? I'm wondering if the opti isn't positioned on the splined shaft correctly...
Old Oct 28, 2005 | 06:14 PM
DarinsTA's Avatar
what he said!
Old Oct 29, 2005 | 01:12 PM
Craver's Avatar
No didnt have to force it on but there was a real nasty crak in the main plug connector that someone just siliconed back together so ordered the whole opti to replace it.
Old Oct 29, 2005 | 07:33 PM
blitzer454's Avatar
If you're getting a spark and the wires are connected properly, but the engine won't start then I suspect that the optispark was not keyed right when you installed the new one. If you do end up tearing it back down try to start the engine before adding the radiator fluid, it will save you a bath in case you have to disassemble again.
97Z28Muscle
Feb 6, 2015 10:44 PM
Catmaigne
Dec 25, 2014 12:16 PM
Injuneer
Dec 15, 2014 09:36 AM
brentbrowning01
Dec 3, 2014 10:36 PM
Russtebo
Aug 31, 2002 08:53 AM
