optispark/cam dowel pin
Old Jan 28, 2004 | 07:25 PM
Zerosheaven's Avatar
Is the optispark/cam dowel pin sopposed to stick out after you put the camshaft sprocket on??? my new cam has a dowel pin that is MUCH shorter than the stock one. the stock one was .75 inches and this new one is like .35 or somethng. so it doesnt stick out at all after the sprocket is on. am i screwed??
Old Jan 28, 2004 | 07:29 PM
indieaz's Avatar
the short pine is needed for the shaft driven 93/94 opti cars like I have. Yours shold have a longer dowel on it like your stock cam.
Old Jan 28, 2004 | 07:50 PM
so what do i need to do to fix it??
Old Jan 28, 2004 | 07:53 PM
indieaz's Avatar
well, unless there is some way to extend that dowel your optispark isn't going to spin. I think you need to call the people you got your cam from and let them know so they can rectify it.
Old Jan 28, 2004 | 07:54 PM
ibanez6rg's Avatar
You need to take that one out and buy a longer dowel pin!
Old Jan 28, 2004 | 08:02 PM
ok im going to sound like a total idiot but can you seriously remove them?? if so how?? could i just switch it with the one on my stock cam...if this was all just a joke .....i hate you
Old Jan 28, 2004 | 08:12 PM
ibanez6rg's Avatar
Put the pin in a vise and twist and pull on the cam. Tap the new one in.
Old Jan 28, 2004 | 08:46 PM
what do you think if i put a little jb weld on the end with another small dowell ontop and extended it that way?? you think it would work?
Old Jan 28, 2004 | 08:49 PM
ibanez6rg's Avatar
Old Jan 28, 2004 | 08:51 PM
i dont own a vice and im weak
Old Jan 28, 2004 | 08:55 PM
ibanez6rg's Avatar
You can find a vise somewhere!
Old Jan 28, 2004 | 08:56 PM
smoknta's Avatar
i would not suggest using JB weld. You should be able to use the one off of the stock cam if you can get it out. My buddy had the opposite problem on his 93. he needed the short one, so we just drove it down and it worked perfect. It should just take a little bit of effort to get out.
Old Jan 28, 2004 | 11:51 PM
That's funny.
Novo
Jun 14, 2016 02:58 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
