optispark
Old Jul 18, 2008 | 09:18 PM
barber33's Avatar
optispark
I just got a 93 camaro lt1 car the car run good up to a hour or so and dies I was told to put a optispark on the car what I would like to know is can you just get optispark I called the gm dearler and they said you got to get the distributor .If you can get the optispark is it hard to install and were do you get it at can you help with a part# or do I need to put the distributor in it and were should I get it at.I new to the lt1
Old Jul 18, 2008 | 09:31 PM
CGrant's Avatar
the optispark is the distributor on our cars
you have the distributor, you have an optical sensor in the distributor and you have a cap and rotor that bolts onto the distributor.
The reason it is call an optispark is cause it has both an optical sensor and cap and rotor (spark) on the distributor.
Old Jul 18, 2008 | 10:57 PM
tlillard23's Avatar
search for "opti"
Old Jul 19, 2008 | 07:44 AM
barber33's Avatar
thank you
Old Jul 19, 2008 | 12:52 PM
Shoebox's website has part #'s for most parts, pictures of the critical components, and a link for GM parts well under what a dealer would charge you:
Shoe's website:
http://shbox.com/1/4th_gen_tech1.html
Part #'s:
http://shbox.com/1/Parts.htm
Photos:
http://shbox.com/1/component_location_views.html
Where to buy:
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
If the car runs fine for an hour, something may be overheating. Items that can "break down" when they heat soak include the Ignition Control Module (Shoebox has a method for spacing it off the head to reduce heat soak), the optical sensor in the OptiSpark distributor, and the coil.
If the optical sensor is having problems, the ECM (engine computer) will set trouble codes. Shoebox also has an instruction on how to flash the codes on the SES light on your 93, by shorting a couple pins in the ALDL (computer data link) connector under the dash by your right knee.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
