optispark
Old Jul 3, 2006 | 04:56 PM
teekettle's Avatar
optispark
open up the opti, cap and rotor had some corrsion clean it up. is that what is making the car miss and not start sometimes.
Old Jul 3, 2006 | 07:47 PM
MEAN LT1's Avatar
Re: optispark
Could be. I would go ahead and replace both items.
Old Jul 3, 2006 | 08:24 PM
1racerdude's Avatar
Re: optispark
It's probably the plugs making it hard to crank.
Old Jul 4, 2006 | 01:32 PM
Re: optispark
Helpful hint - Add a "signature" with basic info about your car, year, model, tranny, and any major mods. Not all years of the LT1 are the same, and the Opti is a good example.
The 93-94's are "no vented" and prone to corrosion from ozone buildup. That would cause the problems you are describing. Moisture buildup will contribute. 95-97 Optis are "vented" and you would need to check the condition of the vent system to make sure it is working correctly.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
