optispark?
Old May 23, 2004 | 08:44 PM
Camaro350z28's Avatar
optispark?
Im pretty sure this is my operater(ME) mistake. i changed my opti this afternoon and i was completely dumb.. when i took off the opti i paid no attention to where it was turned, and then my friend started spinnin it so i was complete unsure on how to install the other opti, so i put it on in hopes of just getting lucky, and now i get no turn over, i have to take back off everything and the opti and this time i want to make sure it goes back on right, is there any markings or anything to line up the opti on the cam so that i know its firing right? blah i hate when this happens but it was my fault so im takin it a lil easier this time hehe thanks guys
Tim
97 camaro btw
Old May 23, 2004 | 08:45 PM
Spinner's Avatar
The opti only slides on your dowel pin one way, it's always going to be in correct time.
Old May 23, 2004 | 08:50 PM
Dave89IROC's Avatar
take it back off, tuirn it over
on the back it will look like a clover leaf, there are three notches between the "leaves", one is different then the other two (strait sides, not indented), that different one goes over the dowel on the cam
From shoebox
Old May 23, 2004 | 08:51 PM
Dave89IROC's Avatar
it will go on wrong, I've fixed a few
Old May 23, 2004 | 08:55 PM
ibanez6rg's Avatar
It will go in three ways, but if you put it in the right slot the first time, you shouldn't have any problems.
Old May 23, 2004 | 09:02 PM
the only slot that is different is the one that i put it in and the car will not fire at all. it will almost run.. i mean it gags running at like prolly 40 rpms and then dies of course.. i know for sure 1 3 5 7 spark plug wires are in the right spot, passenger side was harder to check and i was kinda upset so i didnt look yet think it could be that? blah sucks either way
Tim
Old May 24, 2004 | 03:23 AM
anyway to test if the optispark actually works?
Tim
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
