option deletes?????
Old Feb 13, 2009 | 10:08 PM
93v8clone's Avatar
option deletes?????
what can i delete under the hood without a tune ??????as ar as emmisions go
Old Feb 13, 2009 | 10:59 PM
jtarp's Avatar
Common deletes are the egr and a.i.r..
Old Feb 14, 2009 | 01:12 AM
Green96Z's Avatar
As in you have to pass emissions? How strict? EGR and AIR are required for inspection, not to mention no EGR makes it harder to pass NOx. Removing EGR will give you a SES light (which would require a tune to remove).
And what do you want to keep? By your guidelines, you could delete power steering, A/C, and ABS. A little more info would help.
Old Feb 14, 2009 | 02:13 AM
canuck94z28's Avatar
Egr delete
I,d be leary about deleting the egr as k/r must be monitored closely!I had k/r thru the a++ and putting a new one fixed the problem.The tech section in Car Craft had a real good answer about why deleting it is a bad deal.Btw, i deleted the air pump when i installed headers and didn,t get chk engine light and it cleaned engine bay up and yes i,m still running a cat
Old Feb 14, 2009 | 07:29 AM
93v8clone's Avatar
i am a inspector for ny,so im pretty lenient on myself,we have no sniffer test so im good there i wanna keep p/s and **** i just wanna clean up the bay till later when i do a cam swap then ill retune car .
Old Feb 14, 2009 | 09:54 AM
deerslayinrenek's Avatar
Well from what i've saw and read....Theres no performance gain by removing the EGR and some people are against it because of the K/R. It also doesn't really clean up the engine bay since its on the back of the intake. For this reason, I just left mine on
Old Feb 14, 2009 | 11:08 AM
93v8clone's Avatar
ill prolly leave it on ,for now.........just the air system and other bull**** .how do i do a t/b bypass on a 94 anyway
Old Feb 14, 2009 | 01:28 PM
Tb bypass
Refer to a Car Craft article(Aug/03) and then buy a threaded brass plug from any auto store for 2-3 dollars.
Ks0209
Oct 1, 2015 07:32 AM
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 14, 2015 02:02 AM
