option deletes?????
And what do you want to keep? By your guidelines, you could delete power steering, A/C, and ABS. A little more info would help.
Egr delete
I,d be leary about deleting the egr as k/r must be monitored closely!I had k/r thru the a++ and putting a new one fixed the problem.The tech section in Car Craft had a real good answer about why deleting it is a bad deal
.Btw, i deleted the air pump when i installed headers and didn,t get chk engine light and it cleaned engine bay up and yes i,m still running a cat
i am a inspector for ny,so im pretty lenient on myself,we have no sniffer test so im good there i wanna keep p/s and **** i just wanna clean up the bay till later when i do a cam swap then ill retune car .
Well from what i've saw and read....Theres no performance gain by removing the EGR and some people are against it because of the K/R. It also doesn't really clean up the engine bay since its on the back of the intake. For this reason, I just left mine on
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 14, 2015 02:02 AM
