opti wire harness
opti wire harness
Anyone know where I can get the connector on the side of the intake that the opti harness plugs into?
previous owner has that connectors wires spliced together and every time I would touch near there it would blow the ignition fuse under the hood.
Posted from Camaroz28.com App for Android
Not sure if i'm over looking it or what but I need the pigtail on the main wire harness that the opti harness plugs into on the passenger side of the intake
Re: opti wire harness
AFAIK, they don't sell a pigtail for the harness side. You could buy a new shell and repin it.
I am not good at the electrical side of automotive. I believe me and you talked about this before and I said about just redoing the splices. I will try that first and if that doesn't work I will get in contact with you about how to go about repining it. Thank you for your time tho
CobraEatr
Jul 23, 2002 06:32 PM
