which opti. vented or non vented
Old Apr 22, 2006 | 06:29 PM
GPRacing's Avatar
i have a 94 camaro with the 2000 front end converion and the guy that owned it before me siad that he put a new motor in it before i bought it. and now the opti is messing up and im not sure if it has vented or non vented. i was wondering if i could get some advice or even pictures to compare what i have. i have heard that the later model 94 have the vented one and im not sure if he put a 95 one in or nt. thanks.
Old Apr 22, 2006 | 06:43 PM
Demon's Camaro's Avatar
Re: which opti. vented or non vented
Easiest way is to see whether or not there is a hose coming from the optispark to the intake elbow. If so that means there is a vented opti in there.
And make sure it is the optispark, there a pain in the *** to do and it may be something much more simple.
Old Apr 22, 2006 | 08:09 PM
97firechicken's Avatar
yes there will be a tube going to the top of the opti and they arent to hard to change, just do some research and you will be fine.
Old Apr 22, 2006 | 08:40 PM
OBE1 95Z28's Avatar
Why are you convinced it's the opti? It can be an awfully expensive fix if you're guessing.
Old Apr 23, 2006 | 08:43 AM
GPRacing's Avatar
the car has 130000 miles and it has been missing for a while and i was going to put wires on it but i was just going to do the opti so it will be done. i heard these things just go on you any time.
Old Apr 23, 2006 | 12:27 PM
OBE1 95Z28's Avatar
If it's the original opti, than I would definitely replace it with 130K miles. How about the plugs?
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
tdigger9899
Sep 7, 2015 10:56 AM
whitehooptie
Jul 12, 2015 06:10 PM
Jul 10, 2015 02:23 PM
