Which opti vent hoes goes where?
Old May 13, 2005 | 10:27 AM
Beyonce Knowles's Avatar
Found a diagram on shoebox's site, but it doesn't show which hoes goes on which hole on the opti. Does it matter? Just tell me which one goes to the bottom hole on the opti, the one to the intake manifold or intake air duct, thanks.
Old May 13, 2005 | 10:32 AM
kainZ's Avatar
Re: Which opti vent hoes goes where?
http://www.rpi.edu/~roghab/camaro/pr...cuum_problems/
Look here, I have copies of shoebox's pics, and there is one set which show where they both go.
If you need dialup versions, look here:
http://www.rpi.edu/~roghab/camaro/di...cuum_problems/
Good luck!
Old May 13, 2005 | 10:42 AM
thanks! but I still couldn't tell which one went to the upper and which to the lower hole in the opti. Did I miss a picture in there?
Old May 13, 2005 | 10:51 AM
kainZ's Avatar
This picture shows where each line should go.. (the black text and white arrows point it out):
http://www.rpi.edu/~roghab/camaro/pr...um_harness.jpg
This picture shows the line which goes from the intake mani to the opti and which side goes to which spot:
http://www.rpi.edu/~roghab/camaro/pr...acuum_hose.jpg
And, from there, you'll be able to figure out which line goes to the intake elbow
Old May 14, 2005 | 09:09 AM
You can't tell from this ?
Old May 14, 2005 | 10:11 AM
doh! now I see it. For some reason I thought it was a picture of the intake manifold. Sorry for the idiocy.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
colts0455
Sep 27, 2015 01:07 PM
tdigger9899
Sep 7, 2015 10:56 AM
