opti vacuum
Old Sep 14, 2005 | 05:13 PM
acslinger2525's Avatar
opti vacuum
I have put 5 opti's on my car since the engine rebuild. Apparently, i did not put the vacuum lines back on correctly. The opti's are lasting about 2 weeks max. I was wondering if not having the vacuum lines run correctly to the intake and the elbow would keep cause the rotor button to disintegrate. The rotor button is the only think that ever messes up. The engine is turned about 6200 with the cc305 cam, the usually bolt ons. The opti usually goes out when i am in upper rpms. Just trying to find out what i actually need to do to get some quality out of this car.
thanks
Old Sep 14, 2005 | 05:24 PM
Dave89IROC's Avatar
Re: opti vacuum
you check your cam dowel length?
http://web.camaross.com/forums/showt...t=dowel+length
Old Sep 14, 2005 | 09:17 PM
Re: opti vacuum
Opti vacuum.
The blue pieces need to be on the hose to the intake.
Old Sep 14, 2005 | 09:40 PM
Dave89IROC's Avatar
Re: opti vacuum
yeah, shoebox is the man
however, the vacuum routing should not make the rotor disentigate in 2 weeks, the most common cause of that is the cam dowel being too long
Old Sep 14, 2005 | 10:40 PM
Re: opti vacuum
Just covering the question about vacuum. I agree about the dowel pin.
Here you can see the difference in a stock 1995 dowel pin and a pin that might come in a Comp cam.
The pin on the right is an opti destroyer . Comp's install instructions say to always check the dowel pin for proper length in your application.
Old Sep 15, 2005 | 07:45 AM
Re: opti vacuum
ThANK YOU ALL
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
tommalcolm
Sep 11, 2015 03:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
