Opti Upgrade? Any write-ups?
Old Mar 10, 2003 | 12:30 AM
94T56T-TOPDREAM's Avatar
Arrow Opti Upgrade? Any write-ups?
How hard is the upgrade from the 94 opti to the vented 95 opti? The opti was changed 2 years ago and it is already time for another one. How do I upgrade to the 95 vented Opti. Where can I get the parts and instructions to do it? Is it worth the extra effort to upgrade it to the vented opti?
Does Anyone have any write-ups on how to do it?
Old Mar 10, 2003 | 12:44 AM
allmotorta's Avatar
Absolutely everything you need to know here---> http://para.noid.org/~muttvette/opti.html
Old Mar 10, 2003 | 09:18 AM
anyway to do this without changing the timing cover and cam and all that expensive stuff.
Old Mar 10, 2003 | 11:30 AM
You must change the cover. If you looked at them, you can see that the 1995 has a different hole for the vented opti's drive mechanism. You could have your cam drilled out in the front instead of buying a new one.
Victor Lamb
Aug 26, 2017 02:52 PM
blkWidow
May 3, 2015 08:42 AM
ModdedNerd
Feb 5, 2015 04:37 AM
BlackHawk T/A
Aug 28, 2002 03:13 PM
