Opti/Trouble Code Questions
Old Mar 22, 2003 | 07:29 PM
AmericanMuscle33's Avatar
Lightbulb Opti/Trouble Code Questions
Ok here's the deal. I was throwing TC's 16, 36, 41, and 42. I just took a DVOM and ran some tests. I tested the voltage coming from the PCM headed towards the LOW RES SIGNAL at the Dist. and got a reading of 5.01V. I also got the same reading for the HIGH RES SIGNAL. I know both those are the exact voltage they should be. My problem is intermentant, and appears to be heat related electrical component failure. So, this leaves me with a 99.9% certainty that the electronics in my dist. have taken a dump. I also tested the ICM, and found no problems, it appears those codes (41,42) only tripped once, and never again. What I need to know is if I can buy just the Electrical sensor/component that is in the Opti, instead of replacing the whole dist.? I rebuilt the Dist. about 1/2-1 year ago. I am tempted to tear apart the car and look at the opti right now, but would rather wait until I have new components to put in. Any help or idea's would be appreciated...Thanks,
Old Mar 22, 2003 | 07:35 PM
BTW
BTW, if any randomn quotes or phrases show up in my signiture please disregard them...(i.e. I love Mustangs, Fluffy kittens, and Oprah) a friend of mine has access to my computer, and I forget to log out, so he keeps ***cing with me...
Old Mar 23, 2003 | 12:35 AM
TTT
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
johnsocal
Aug 29, 2002 10:01 AM
91Bird305
Aug 5, 2002 01:39 PM
