opti and timing chain
Old Nov 30, 2007 | 10:55 PM
weq92f's Avatar
94 T/A 6sp 120k miles
Will be tearing into this thing again shortly to replace the opti, plugs/wires/ o2 sensors and A/C components.
What else would be required to go ahead and put in a new timing chain set?
Thanks,
-weq
Old Nov 30, 2007 | 11:01 PM
Wild1's Avatar
Gaskets:
Water Pump
Timing Cover
Water Pump Seal
Oil Pan Gasket (if your are not careful)
Coolant or save what you drain... I'd recommend draining the plugs from the block to so nothing spills on the opti during the transition.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
