Is this opti symptoms
Old Apr 18, 2003 | 05:59 PM
1BadBrd's Avatar
I had two optis already and they felt like a dead cylinder. Ran shippy although the RPM range.
Now this time it feels like it's hitting a rev limiterr. It happens sometimes and not all the time. Mostly in the 3000+RPM range.
Twice a code of 16 and 36 came up just when i start the car. If i shut it off it will not return. I know 16 and 36 or opti codes, but it only threw it twice. Once was right after the longtube install about 2 months ago and yesterday was the second time.
After the second time it happened the same way. Came on only when started. After i shut it off and let sit for a couple of hours while playing pool, i drove it home with the SES light on and she ran great, maybe the best yet.
Anyway the problem is like i'm hitting a rev limiter and it slowly goes through the RMP range after that.
Is this opti time (again) or ashould i check something else?
Old Apr 18, 2003 | 06:17 PM
95loveaffair's Avatar
Bad plugs? Bad wire, arcing?? I'd really check over everything before popping for another opti.
Old Apr 18, 2003 | 06:18 PM
chevy94c's Avatar
I would check the connections and try plugs and wires before getting a new opti.
1BadBrd's Avatar
plugs and wires have 100 miles on them
Old Apr 21, 2003 | 06:17 PM
1BadBrd's Avatar
TTT
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
tdigger9899
Sep 7, 2015 10:56 AM
