opti swap, am i right?
Old Dec 11, 2006 | 10:06 PM
Daniel6718's Avatar
ok let me start i have a 94 and a 95 lt1.
im going to build the current 94 car but want to do a cloyes double roller. so my plan is to take the 94 stuff and put it on my 95 car and my 95 stuff on my 94 car...
i would have to swap harness(opti only)
timing covers
and cam gears? the 94 is splined and 95 has a hole in it
and opti's
this means my cam in the 95 wont have to be changed? because the splined shaft only goes into the cam gear no the cam correct?
thanks
Old Dec 11, 2006 | 11:37 PM
94 NO TOP Z's Avatar
Sounds right. 95 cam will work with 94 setup. The '95 opti won't work with a STOCK '94 cam. If you have an aftermarket cam it will have the bigger recess for the '95 opti.
You will also have to go with an electric water pump if you don't use the LT1 timing set.
Old Dec 12, 2006 | 06:06 AM
sssalah's Avatar
Cam dowel pins are different lengths so the cams or the pins (if that's possible) must be swaped.
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
KamikaZ28
May 28, 2015 12:45 AM
Bxlt1
18
May 27, 2015 05:00 PM
zxtce
May 7, 2015 08:53 PM
dobe
Jul 31, 2002 01:28 PM
