opti stabilizer...
Old Nov 8, 2007 | 11:20 PM
thebufenator's Avatar
opti stabilizer...
So after I purchased an EWP, I was told I no longer needed the LT1
style timing chain.
So I bought a cloyes timing set, way cheaper.
Well I was preparing for my top end build, and just realized taht the 93-94 style opti's have the splined drive that mates with the cam sprocket.
The cloyes doesn't have that.
Am I correct in assuming that I now need to delay the build *again* and go find an LT1 cam gear?
Old Nov 8, 2007 | 11:23 PM
mdenz3's Avatar
That or convert to a vented Opti.
mdacton's Avatar
no you need to get the newer style opti or run a different timing set.
I would go for the vented opti and use the double roller
Old Nov 8, 2007 | 11:25 PM
Do you know where I can purchase just the gear from?
Summit and others only seem to sell the LT4 extreme duty set.....
Old Nov 8, 2007 | 11:26 PM
vented opti......
Is there someplace to buy the vaccum stuff and timing cover from?
Old Nov 8, 2007 | 11:28 PM
mdacton's Avatar
Originally Posted by thebufenator
vented opti......
you can find the cover used
I think you can still get the vac. harness from the dealer
Old Nov 8, 2007 | 11:51 PM
mdenz3's Avatar
You would need to buy the cam gear from the double roller non-vented opti timing set. It probably cost the same to just convert to a vented Opti.
Old Nov 9, 2007 | 01:10 AM
so do I need the vented opti wiring harness?
gmpartsdirect has it....for $113......
Old Nov 9, 2007 | 03:33 AM
SS RRR's Avatar
I've never seen this question asked or answered before, but why can't the cam timing gear be machined for the splined shaft? Can't cost that much to use a smithy on it?
.... or would that jeapordize the integrity of the cam bolts due to lack of material? I'm not familiar w/ the splined setups...
Old Nov 9, 2007 | 07:37 AM
the splined setup has a tighter diameter then normal.
Old Nov 9, 2007 | 07:49 AM
The Engineer's Avatar
I would just convert "everything" to 95 and up configuration w/ vented Opti. I'm sure you'll like that better, once you've done the upgrade.
WD
Old Nov 9, 2007 | 08:46 AM
You can get a vented opti harness from Casper and a couple other places for 1/3 of that.
Old Nov 9, 2007 | 01:27 PM
Illustrating what "thebufenator" pointed out.... you can't machine a large hole to turn it into a smaller hole.
Old Nov 9, 2007 | 04:20 PM
SS RRR's Avatar
I always thought the hole on the cam gear was relatively the same size as one which used a dowel. I learnd'd sumthin!
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
