opti-spark install question
Old Nov 6, 2005 | 09:22 PM
busta9876's Avatar
I've got a 1995 LT1, pin drive opti, with LT4 roller timing set. Found out I ordered the production LT4 set, NOT the extreme duty,
anyways
with timing marks lined up on the cam and crank sprocket, I installed the timing cover, opti, has 3 holes for pin to go in. one hole has a slot in it. I made sure the pin went in the hole with the slot.
okay i put all the valve train stuff on and went to start adjusting my rockers. when i turnd over the engine I noticed that #1 cylinder intake valve opend imediatly.
Now on classic GEN 1 SBC, didn't the cam and crank spockets timing marks line up at TDC compression stroke?
The LT1 timing marks are lining up at TDC Exhaust stroke.
anyways...just noticed this wondering if anyone else has... that means with timing marks lined up, putting the opti on the rotter bug would point to #6
Old Nov 6, 2005 | 10:37 PM
Re: opti-spark install question
When the dots on the cam and crank gears are lined up and together, you are at #6 TDC.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
