Opti-Spark conversions
Old Dec 23, 2007 | 08:16 PM
  #16
3DFORMULA's Avatar
Originally Posted by Injuneer
As Shoebox correctly pointed out.... it has NOTHING to do with OBD. For F-Bodys: 93 and 94 cars had the unvented, splined shaft driven Opti. In 95, they stayed with the OBD-I PCM, but switched to the 95-97 vented Opti, driven by the cam dowel pin. If you convert the cam, timing set, timing cover and wiring harness extension, you can run the 95-97 vented Opti on a 93-94 engine.
Better worded than what I had previously done for him. Not the best speaker.
Old Dec 23, 2007 | 08:20 PM
  #17
Most cams come with the larger pilot hole required for the pilot shaft on the 95-97 vented Opti. That way, you can use the cam with either, just by adjusting the length of the dowel pin.
Conversion info:
http://para.noid.org/~muttvette/opti.html
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
