opti spark?
Old Apr 24, 2004 | 03:38 PM
got8?'s Avatar
opti spark?
could an opti spark problem be causing loss in low end tourqe the car pulls really strong on the high end at like 4-6 grand but barley spins halfway through first gear when i floor it!!!!!!! I ran a 15.1 at 93 mph with 2.3's 0-60ft times with my stock 2.73 gears
Old Apr 24, 2004 | 03:54 PM
Scream And Fly's Avatar
Anything is possible, but from what you're describing, the Optispark is not the likely culprit. Usually, when an Optispark is going bad, you'll get misfires and hesitation in the upper RPM range.
There are so many variables to check:
I would check the throttle body first. Maybe it needs a cleaning.
Greg
Old Apr 24, 2004 | 04:00 PM
got8?'s Avatar
could it be a leak in the intake manifold
jmadoll
Jun 10, 2015 04:41 PM
beltrunner
May 17, 2015 10:18 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
DTK
Aug 14, 2002 06:14 AM
