opti or something else?
Old Oct 27, 2007 | 12:58 AM
compt/aclone's Avatar
Ok my car is in my sig but it wont start sometimes. It turns over fine but just wont fire up, then when it actually does fire it will run fine till it warms up and then it seems as if there is a rev limiter around 3500rpm and the warmer it gets the lower the rpms get.It will spit and sputter and wont ever clear out. Im lost so please let me know your thougths thanks
the car has 130k and its the original opti with a 1000mile msd cap and rotor and the icm and coil was also replaced
Old Oct 27, 2007 | 01:42 AM
brianswimmer23's Avatar
yea it sounds like the opti wow thats a long time to have the same opti! surprised it has lasted this long. goodluck changing it.
Old Oct 27, 2007 | 03:53 AM
hektyk's Avatar
Yeah it def has the signs. Could be something else too though, Changing the opti isn't that bad. It's a little time consuming but nothing to hard to bear.
Old Oct 27, 2007 | 09:39 AM
yeah i replaced the cap and rotor myself so it wasnt to bad...but hektyk what else could it be that i havent replaced?
Old Oct 28, 2007 | 10:19 PM
bump for some help
Old Oct 28, 2007 | 10:30 PM
Fatdog2's Avatar
Might be the water pump leaking down onto the opti.Hope this helps.
Old Oct 29, 2007 | 02:52 AM
hektyk's Avatar
Yeah that is what happened with mine also. My WP had a slight leak and it kept shorting the opti out, finally I got another to put on there. The 2nd new one in 2 months and it poured out water. Look at the plug wires and see if they are still getting spark when it is messing up. Have you checked the plugs to see if any of them are fuel fouled? I would just hate for you to pay for an opti and do all the work just to find it still didn't help. I ended up going through like 2000.00 trying to find my problem, I just never thought it would be the opti since I had just put one on there. But you never know with these crazy f-bodies. your not in the dfw texas area are you?
Old Oct 29, 2007 | 07:59 AM
no sorry im in SC but someone on ls1tech said that it may be the tps so i might try that today but i will check and see if the water pump is leaking that will help if it is
Old Oct 29, 2007 | 09:27 AM
Have you checked it for codes?
Old Oct 29, 2007 | 09:31 AM
yes but there are no codes due to being a 93 and the computers do not read as much
Old Oct 29, 2007 | 09:32 AM
Sure they do..... there are dozens of codes, including the ones for a faulty Opti optical sensor, and for the TPS you are apparently going to replace for no reason at all.
Old Oct 29, 2007 | 02:38 PM
hektyk's Avatar
Ya I agree, It would throw codes for either of those. Have you replaced the fuel filter and checked the fuel pressure on the back of the manifold?
Old Oct 29, 2007 | 07:39 PM
94_PatriotRed_Z's Avatar
When my opti went bad it would only throw the code after warming up and going in to open loop. It would run just fine when in close loop but as soon as it got hot it would miss and run like crap until it threw the code and it would run fine agian. Sounds like an opti to me
Old Oct 29, 2007 | 11:18 PM
hektyk's Avatar
Yep exact same thing with me.
Old Oct 29, 2007 | 11:39 PM
SS RRR's Avatar
Before jumping on the "change the opti" bandwagon you should check your fuel pressure to see about the fuel pump and make sure to rule that out. It's cheap and easy to do.
