Opti sheild idea?
Old Mar 5, 2006 | 04:39 PM
jm90camaro's Avatar
Opti sheild idea?
Hey guys, i got a wild idea in my head today to try and cure or atleast cut down on the problem of moisture getting to the opti. I am trying to configure something will encase the opti to prevent most mositure from getting to the opti yet allowing for all electrical wiring to still go to it. I'm thinking something made out of a thin aluminum or possibly tin that can be bent to work in the location of the opti. If anyone has any insight on this idea, please share as it will help all us LT owners.
James
Old Mar 5, 2006 | 04:47 PM
turbo_Z's Avatar
Re: Opti sheild idea?
Sounds like a lot of work for what you are trying to accomplish. If you are really worried about moisture then why not get a $2 tube of RTV and seal the case with it?
Old Mar 5, 2006 | 05:18 PM
jm90camaro's Avatar
True, see, I'm new to these motors, so i have no idea as to what people are doing to prevent moisture from hendering the opti. Guess my research hasn't really brought any preventative methods to my awareness. Thanks.
Old Mar 5, 2006 | 06:48 PM
atljar's Avatar
For the most part, problems with the opti are overstated IMO. Yes moisture gets to them, but it does the same for any distributor. Ours are just in a crappy location, so people complain about changing it because it takes more than 10 min like a stock style distributor.
As for a shield, dont think you would ever get one in because of the tight clearances between the pump, front cover, balancer and the opti.
If you are worried about it, RTV the case shut. Another option is upgrading to the 95+ vented style
Old Mar 5, 2006 | 06:52 PM
ajschult's Avatar
I went to town with a tube of rtv wherever there was a seam. We'll see if it holds up..
Old Mar 5, 2006 | 07:16 PM
TransAm396's Avatar
ajschult..i was just about to say that...coat it in a thin layer of RTV
ad356
Apr 22, 2015 08:35 PM
armedtrigger
Feb 24, 2015 08:30 PM
maybe2fast
Feb 5, 2015 05:14 AM
CR97WS6
Aug 19, 2002 08:44 PM
