opti question
Old Aug 22, 2004 | 10:34 AM
lt195ta's Avatar
opti question
got a replacement motor for my car for a good deal....new with no miles
its a 94 LT1 and I have a 95 trans am
If I open it up, the warrenty is void.
Can I run the nonvented opti in my car. I hate to but it seems the only thing possible.
Cant sway cams and I know that the dowel pin has to be on the cam to sit in the groove of the vented opti.
Any input.
Old Aug 22, 2004 | 10:41 AM
will62085's Avatar
Re: opti question
i put a vented opti cap and rotor on my old 94 non vented dowel drive distributor...it should work for you too
Old Aug 22, 2004 | 11:11 AM
lt195ta's Avatar
Re: opti question
how....anywhere to see pictures
Old Aug 22, 2004 | 12:51 PM
lt195ta's Avatar
Re: opti question
can i just run the car with the unvented?
Old Aug 22, 2004 | 12:59 PM
will62085's Avatar
Re: opti question
yeah you can, i dont see why it would be a problem, but the cap and rotor bolt up just the same, go to autozone and get a cap and rotor for a vented opti, and just swap them out, it was pretty simple
Old Aug 22, 2004 | 01:09 PM
Mtrhds94Z's Avatar
Re: opti question
Any input.
The cam needs a nose drilling in addition to the longer dowel pin to run a vented opti [and the 95 timing cover of course]
If i understand the question, you have a 94 motor with a 94 unvented opti that you swapped into a 95.. [and can't upgrade to vented due to warranty issues, etc.]
You need a 94 'opti harness' that will plug from the passenger side of intake manifold 4 prong weatherpack connector to the 94 opti.. [the vented opti plug is longer, tho it MAY fit.. never tried one.. I do know that the short[94] one does NOT fit a vented opti.. you could try it first.. it may fit..
You should be able to get one cheap from anyone that has done the vented opti upgrade..
As far as the venting goes you can just not vent it.. or do the vented opti conversion, since you have the vacuum harness already in place.. [more to it though than a cap and rotor kit]
See here:
http://www.corvettefever.com/howto/16758/
Old Aug 22, 2004 | 01:13 PM
Mtrhds94Z's Avatar
Re: opti question
will62085 that cap you refer to I assume has the nipple for the vent?Don't forget the housing needs one fabbed up also..
How much was the cap and rotor kit at AZ?
Was it a 'Well's' brand? or?
Thanks!
Old Aug 22, 2004 | 01:24 PM
will62085's Avatar
Re: opti question
Thanks!
ohh yeah i forgot about the one on the housing, i dont know what brand it was, that car has been sold for a while now, i just hooked the one vent on the cap to the intake, i think the kit was around $120, dont quote me on that though its been a while
Old Aug 24, 2004 | 11:01 PM
lt195ta's Avatar
Re: opti question
ttt
Sergio
Jan 27, 2016 04:27 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
