Opti question....
Opti question....
I am doing a cam swap right now and when I looked at the opti I noticed that there is a lot of grime on the plug wire boots and oil near the opti. Is that not good, do you think that could damage the opti? I was getting hesitation in the upper range of the RPMs when the car was running hot, but only when it was running hot. Other than that I can't see anything being wrong with my opti and I don't wanna replace it if I don't have to because I really don't have the money, but I don't wanna run into a problem where it dies like a week after the cam swap....
Thanks guys
Thanks guys
Originally posted by akobak
get the opti from Dal and itll be more than half the normal price around 300 or so. Do a search for his number. I would replace it if its old.
thats decent mileage for the opti.. wheres the oil comin from ?
clean it up a bit and see how it goes, be pretty ****ty to spend 200+ dollars for no reason.. but if there is a big doubt that the opti is damaged, just replace it :P
Yea i definitely don't wanna spend the money if i don't have to...there is not a huge doubt that anything is wrong....i guess i can pull it and clean it up and see what it looks like...
Originally posted by lt1g3n
just be careful not to spill any coolant on it =P .. or anything fo that matter
Thanks for the help guys
Formula Steve
Sep 19, 2023 08:31 AM
