Opti problems (I think)
Old Dec 29, 2006 | 12:45 PM
bitchin94's Avatar
So just a few days ago my car started to miss at 1500 to 3000 rpms, but at WOT it will go away and now two days later it is geting worse. So far I havent looked at anything. So I'm guesing it is the opti but could it be somthing else. And also what is the best opti out there.
Old Dec 29, 2006 | 08:08 PM
OBE1 95Z28's Avatar
Not a good troubleshooting technique to guess it's the most expensive part Common sources for misses are bad/burnt spark plug wires, fouled plugs or a marginal coil. Yes it could be your opti, but rule out the other parks first.
Old Dec 29, 2006 | 11:43 PM
bitchin94's Avatar
well I took it for drive and it sounds like it is runing fine in park and nutral but when I put it in gear it starts to miss and stumble and just run like s*** so know I'm really confused would the trany have any thing to do w/ the motor sounding like it is missing and how can I fix this
Old Dec 31, 2006 | 04:30 PM
bitchin94's Avatar
Anyone????
Old Dec 31, 2006 | 05:11 PM
GMRL's Avatar
Is it showing any codes? Do you any way to scan it or do some data logging?
Old Dec 31, 2006 | 05:13 PM
reamo04's Avatar
my car had the same problem, except my miss was right at 2000 rpms, turned out to be the plugs, changed those and it went away. Im gonna do plug wires too, just to be safe
Old Jan 1, 2007 | 10:36 AM
bitchin94's Avatar
No I have not scanned it but it doesn't show a SES light (which I know doesn't mean it won't show somthing when scanned) I think I am going to change the plugs and wires and see if that wont' help
greenzee28
Mar 26, 2015 09:13 AM
grabbem88
Mar 18, 2015 01:25 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Injuneer
Dec 15, 2014 09:36 AM
