Opti Keeps EXPLODING =/
Old Jul 27, 2003 | 10:59 PM
  #16
Originally posted by InjectedSS
wait your sayin to RULE THIS OUT as being the problem? or do u mean i should definately look into this as being the cause? also im running the ED timing chain so i guess we couldnt compare out numbers like that...
I'm saying, do what you have to do to prove to yourself that the dowel is not the problem. Most everyone's "exploding opti" condition has been caused by the dowel.
Yeah, better to measure total dowel length. Mine was .650", but it could have been a little longer and been ok.
Old Jul 27, 2003 | 11:02 PM
  #17
63SSRagtop's Avatar
Certainly agree.. if that dowell is too long it will put too much force on that high tech plastic rotor.. cam end play may be in the mix also.. rule out the most probably then scratch yer head if that isnt it..
Old Jul 27, 2003 | 11:08 PM
  #18
InjectedSS's Avatar
ahhh ok so what do u mean by using the clay? where should i put it? inside the lil hole were the dowel goes?
Old Sep 9, 2003 | 07:40 PM
  #19
InjectedSS's Avatar
just had to update this thread! turns out the problem WAS indeed the cam dowel! after like 4 opti's and two grinding sessions it's finally grinded down to where it doesn't hit and ive been running strong for about 2 months now thanks guys
Old Sep 9, 2003 | 09:09 PM
  #20
... a resurrected post.
This will help when someone uses the search. Glad you posted back.
Old Sep 10, 2003 | 12:20 AM
  #21
InjectedSS's Avatar
that's cause i've been there and done that with the search... someone has a problem and asks for help but they never usually post the dayum outcome
people need to learn how to play the game
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
