opti install help needed
Old Oct 12, 2013 | 08:55 PM
pimpinphil's Avatar
just ordered a new msd opti. and kept my original opti in the same position it came out in,so i could setup the msd the same way... however showing a friend my progress,they happened to spin the opti wheel on the original so that option is now out.... anyways need help lining up the timing marks, from what i understand ther is a notch on the crank hub,and that should be in the 12 o clock position lined up with the a notch on the timing chain cover,and what i am understanding is the cam "notch in the 6 oclock position means the engine is on tdc spark stroke for cylinder 1??? so should be able to open up the msd and set it up firing on cylinder 1??? is there a better way or is this the way? i have tried some searching, just havent found much on this issue. thanks for your time.
Old Oct 12, 2013 | 09:21 PM
Re: opti install help needed
This is all you need to know.
Old Oct 13, 2013 | 02:48 PM
pimpinphil's Avatar
sure was thanks a lot shoebox.
Old Oct 16, 2013 | 04:37 PM
mstamey98's Avatar
shoebox is this the same setup for 1993 z28..mine will crank then shutoff..it will not stay runnin..ive changed EVERYTHING on this car and no luck
Old Oct 16, 2013 | 05:21 PM
No. 93/94 use a different drive system for the unvented Opti. Rob/Shoebox has a picture for you too:
http://shbox.com/1/93-94_opti.jpg
Old Nov 12, 2013 | 07:05 AM
pearlpurple's Avatar
In essence the 93/94 OPTI is easier since all you do is line up and go?
Old Nov 12, 2013 | 03:02 PM
IDK about easier. You have to pay attention to what you are doing in both cases.
Old Nov 12, 2013 | 03:12 PM
People manage to screw up the alignment of both types, about equally.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
