opti index
Old Sep 20, 2008 | 08:41 PM
pyro719's Avatar
opti index
Ok Im putting my opti back on and I can get the drive spline lined up correctly I think? The crank and cam dots are lined up and my rotor is pointing @ 1 oclock. Is this right? Just want to make sure it is indeded right before I put it back together.
Old Sep 20, 2008 | 11:27 PM
With a splined drive opti all you have to make sure is that the splines are indexed correctly. Sounds like you are at #6 TDC, which would be correct if the cam and crank gear dots are together. All sounds ok.
http://shbox.com/1/93-94_opti.jpg
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
bunker
Aug 1, 2015 10:10 PM
asilomar244
Jul 12, 2015 05:53 AM
