Opti going bad Need advice
Old Feb 24, 2003 | 01:33 PM
  #16
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
they have an opti solution in the Advanced tech for $700
just ask the cali section
I've already helped a few guys for nothing but KFC (mmm crispie strips)
someone helped me with an oil pump swap for free,
God blessem
Old Feb 24, 2003 | 01:48 PM
  #17
TMDZ28's Avatar
God blessem
solutions?? for $700 and no more opti problems?? are you for real??
Old Feb 24, 2003 | 03:03 PM
  #18
Indy93Z28's Avatar
Hey TMDZ28 my car is running kinda crappy too but I'm not having overheating problems... my temp stays under 180 usually...
Maybe my water pump is not leaking as bad as your's
Old Feb 24, 2003 | 03:19 PM
  #19
TMDZ28's Avatar
....my car is not overheating too...well, if i run on the freeway, my water temp is below 180.....but i did a compression test and i found out that my water pump is leaking.....oh well, what can i do
Old Feb 24, 2003 | 03:45 PM
  #20
Wild1's Avatar
That's the catch 22. Your opti may be fine, just that the water pump is dousing it with coolant. You can change it at the time you change the waterpump OR you can wait to see if it dries up. But, if it doesn't ..... it'll all have to come apart again.
Old Feb 24, 2003 | 03:57 PM
  #21
TMDZ28's Avatar
i think i'll just change the water pump for now, because this "running like crap" thing happens when first i bought the car, then after replacing the thermostat with 160* and i did a TBB....my car took heat better than before.....so i'm hoping that my opti is still good and only my water pump is the burden...hopefully
Old Feb 24, 2003 | 03:59 PM
  #22
Blk94Z28LT1's Avatar
ram air is right, it's not just a simple replacement from unvented to vented. I still don't understand why GM didn't come up with a replacement vented opti, to fit the 93 and 94. I think they could have come up with a kit. There is a way to convert your non-vented to a vented using a vented cap and rotor kit. vented opti vacuum hose ***'y. and then adding a fitting to your non-vented opti. I believe i saw it on a corvette web page somewhere. May try google search.
Old Feb 24, 2003 | 06:41 PM
  #23
Indy93Z28's Avatar
Well I'm just going to replace both the opti and water pump to be sure. I imagine after driving the car for a couple months in this condition the opti has been damaged.
Old Feb 24, 2003 | 06:51 PM
  #24
RCF925's Avatar
Get a new opti and vent it yourself, You can buy the stock vacuum harness from GM for about $25.00 and the other fittings from an auto parts for about $5.00. I did mine and swapped out the waterpump at the same time and it took about 5 hours and thats with a blower and aftercooler to mess with.
Old Feb 24, 2003 | 06:58 PM
  #25
Indy93Z28's Avatar
Hey come do mine then we both live on the central coast I see
Old Feb 24, 2003 | 07:07 PM
  #26
TMDZ28's Avatar
any instruction on how to vent the opti myself?? i would like to do it....but i can get a vented opti for free though...now i'm all confused
HectorM52
Jul 30, 2017 11:46 AM
Jun 6, 2015 08:27 AM
ad356
Apr 11, 2015 10:30 PM
Blood type Z28
Apr 8, 2015 11:34 PM
wytblur
Aug 5, 2002 02:03 PM
