opti failure.. (#5)
Old May 21, 2009 | 01:56 AM
  #16
wheelliftnpony's Avatar
Originally Posted by ACE1252
I don't think so myself.....the cam seal....maybe...but even then....
Are you sure you are installing them correct? There are two o-rings on the back shaft of the opti(on the '96's). The second o-ring can be a pain to seat in the cam. I had to use oil and wobble it into the cam. If you don't do this correctly, it will put continuous pressure on the rotor which may cause it to fail early. I went for 70K+ miles on one opti....been on the car since it got it back in '99. I only replaced it(along with water pump, cover seals, etc), because I was doing a cam swap.
btw, I use only a GM opti.
both msd's held up better than stock jobs mainly because mine is a 94 with a non vented opti from factory. the msd is the only vented distributor for mine, and ill stick with that. the seals you are talking about are for the later setup. mine is a spline drive, not really any seals. everything has been done correctly, but i noticed today that there was actually a little oil sitting on top the opti. how in the world does that happen?
Old May 21, 2009 | 02:46 AM
  #17
ACE1252's Avatar
Ahhh, I totally forgot about the non-vented unit. That explains it. I think you can convert....but you would have to change cams correct? In the long run it may be worth it.
Is your water pump drive seal above it ok?
Old May 21, 2009 | 05:32 AM
  #18
To convert to an AC/Delco vented Opti, he would have to change the cam (deeper pilot hole), the cam sprocket (no splines) the timing cover (larger hole for back of Opti) and the harness extension (longer connector).
Old May 21, 2009 | 05:44 AM
  #19
Guest47904's Avatar
Guest
You could modify an OEM yourself
Then there's this:
http://www.corvettefever.com/howto/16758/index.html
Old May 21, 2009 | 12:42 PM
  #20
ACE1252's Avatar
Originally Posted by speedygonzales
That's not a bad idea.
Old May 21, 2009 | 03:31 PM
  #21
SweetZRag's Avatar
Originally Posted by Injuneer
Some people have managed to get the MSD to work reliably. Definitely better then the Accel (avoid at all costs). MSD keeps ironing the bugs out, as people find new problems. The current problem seems to be the rotor screws falling out. You have to Loc-Tite them before you install the unit. Still questonable whether the MSD is worth the extra $$$$$$$$.
For the record, I have about 47,000 miles on my MSD Opti now. Since the original problem (rotor rubbing the backplane causing shavings) which MSD made good on, no problems at all.
Old May 22, 2009 | 01:50 AM
  #22
thats weird you say that. the rebuilt msd im putting in does that somewhat when you spin the rotor. probly not a good idea to install?
only does it if i put a light bind on the shaft while turning it.
oh water pump seal is fine
Old May 22, 2009 | 12:39 PM
  #23
SweetZRag's Avatar
You better call MSD if that is happening before installing. Mine was one of the very first units they sold and the issue was supposedly fixed since then. Don't install it. Call them.
Old May 24, 2009 | 02:32 AM
  #24
brokegenetic's Avatar
can a leaky front main cause opti sparks to fail? i will be putting my 6th one in this week (2nd MSD).. and that small oozing leak is the only thing that has remained the same through all of them. vacuum lines have been put in correctly, fresh air hose, and i am very careful not to get it wet at all.. they go like clockwork.. about every 10-15k miles. thanks for any help, chris
I had my 160k opti almost give out due to the timing cover seal behind opti leak, I just opened it cleaned it and polished all terminals/rotor, put sealant, rivets and its good now. Have you opened it up yet to see the cause?
Old Jun 3, 2009 | 01:52 PM
  #25
havent had the time to yet, but should be getting to it maybe this week or next. good idea to do timing set,seals and gaskets at 106k? oil pan gasket need replaced as well when timing cover removed? thanks
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
