opti drive seal
Old Sep 28, 2008 | 12:53 AM
94arcticwhiteM6's Avatar
opti drive seal
im replacing the drive shaft seal for the opti tomorrow and was just wondering if there were any tips to make it not leak. this is the third time im replacing it and i dont want to do this again. the second time was due to faulty installation that a friend did, but i should have been watching more carefully so its my faulty either way. the first i thought was in good but it leaked as well. so if anyone knows a trick for the non-vented opti let me know.
Old Sep 28, 2008 | 09:39 AM
Just drive it home "squarely" and it should be fine.
Old Sep 28, 2008 | 10:02 AM
NukeFPE's Avatar
Take the drive spline out. Clean the timing cover recess the seal goes in very well ~ use laquer thinner or brake cleaner. Make sure there are no burs from removing the old seal ~ clean them up w/ sandpaper or a dremel tool. Lightly grease or oil the OD of the new seal ~ I also like to put a little grease on the sealing surface where the spline passes through. Find a socket that is the same diameter as the OD (Outside diameter) of the opti seal & tap on the socket keeping it square to the cover. Done.
Old Sep 28, 2008 | 10:28 AM
I don't ever use any lubricant on the outside of a round seal. They usually have a coating on them that helps to seal it to the cover when it is installed.
Old Sep 28, 2008 | 12:55 PM
i'll give it a shot, thanks shoebox.
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
squarehead
Nov 21, 2014 08:02 PM
The Seer
Nov 20, 2014 06:32 AM
