Opti Dowel Pin
Old Sep 15, 2005 | 01:00 PM
acslinger2525's Avatar
Opti Dowel Pin
mY DOWEL PIN MEASURED .398, IS IT BEING TO SHORT THE CAUSE OF MY OPTI BLOWING UP?
Old Sep 15, 2005 | 01:47 PM
Re: Opti Dowel Pin
.398" from where?
I don't see how being too short would cause the same scenario as too long.
Old Sep 15, 2005 | 04:26 PM
SStrokerAce's Avatar
Re: Opti Dowel Pin
The spec is for around .600 .580-.620 is what I commonly find.
Bret
Old Sep 15, 2005 | 04:58 PM
Dave89IROC's Avatar
Re: Opti Dowel Pin
did you measure from the face of the cam or the face of the timing chain sprocket, and, what year car?
Old Sep 15, 2005 | 06:11 PM
Re: Opti Dowel Pin
1997 and i believe from the face of the timing chain. I am not a mechanic, i am just trying to get this car back running. I put the opti up against it without the timing chain cover on and it felt like to went great. When i took my opti apart, the rotor button was just sitting in it. I replaced it and placed lock-tite on the bolts. I looked at the previoulsy posted picture and my pin looks smaller, but not that much. I appreciate everyones information.
Old Sep 15, 2005 | 06:24 PM
Dave89IROC's Avatar
Re: Opti Dowel Pin
if you measured from the face of the sprocket, that measurement is about right, the sprocket is approx. .220 thick
Old Sep 15, 2005 | 07:53 PM
Re: Opti Dowel Pin
i have everything but the timing chain off it the front of the motor, how much more work is it for a cam removel. Intake and lifters?
Old Sep 15, 2005 | 08:20 PM
Dave89IROC's Avatar
Re: Opti Dowel Pin
on the block, yes, but you still need to pull the rad, and at the very least pivot the A/C condenser up on the lines for the cam to slide out
Old Sep 15, 2005 | 08:31 PM
Re: Opti Dowel Pin
thanks david
tdigger9899
Sep 7, 2015 10:56 AM
reww86
Aug 29, 2015 06:04 PM
Schul365
Aug 22, 2015 10:00 AM
asilomar244
Jul 12, 2015 05:53 AM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
