Opti Delete
Old Jan 29, 2005 | 11:04 PM
c0rey's Avatar
Opti Delete
Hey I was wondering how much in total it would cost to switch from a opti over to a distributor setup. Here is the link I got the idea from.
http://www.96z28ss.cz28.com/photo3.html
Old Jan 29, 2005 | 11:17 PM
Re: Opti Delete
So, if you switched, what will you use to send signals to the computer to operate your injectors? Also if the computer sees no pulses from the opti, it won't allow fuel pump operation.
Old Jan 29, 2005 | 11:43 PM
Cerwin Vega Fan's Avatar
Re: Opti Delete
Yep shoebox nailed it (as always). The guy in your link converted his LT1 over to a carb so the PCM is basiclaly useless. Unless you get rid of fuel injection all together you will need an Opti or something to let the PCM know to fire the injectors.
Old Jan 29, 2005 | 11:53 PM
atljar's Avatar
Re: Opti Delete
I ran a MSD crab cap distributor on mine. This leaves the opti in charge of all things the PCM needs, yet allows a true distributor to distribute the spark. Do a search for "lt1 to distributor" in advanced tech by me, lots of info
Old Jan 30, 2005 | 12:01 AM
Seal's Avatar
Re: Opti Delete
what are you talking bout?
look closely, thats a lt4 intake with injectors...
atjlar uses a dist. but i'm not sure if hes carbed or not
Old Jan 30, 2005 | 12:24 AM
atljar's Avatar
Re: Opti Delete
No im still EFI controlled by stock computer.
The LT4 intake above is still fuel injection. If you want the stock ECM on there, you need the opti res wheels still. If its aftermarket DFI, you could totally eliminate the opti.
Old Jan 30, 2005 | 12:33 AM
Seal's Avatar
Re: Opti Delete
so has switching to that setup helped you at all?
Old Jan 30, 2005 | 12:35 AM
Re: Opti Delete
Opps.
Old Jan 30, 2005 | 12:36 AM
atljar's Avatar
Re: Opti Delete
shrug.
It feels really fast, and the car has not misfired under any rpm/load so far. However its very cold, so the 1st/2nd/3rd is useless. 4th is useless past 75% throttle. Partially the cold roads, partially the power. Our car club is getting a dyno day together in the next few weeks, ill have some tuning results then. Our tracks open end of Feb.
Old Jan 30, 2005 | 12:51 AM
Seal's Avatar
Re: Opti Delete
i dont understand how cold has to do with anything with the dist/timing etc and how ur 1st/2nd/3rd is useles...
do you mean u are like spinning the tires in those gears, or ur distubitor doesnt like to work in the cold
Old Jan 30, 2005 | 01:18 AM
atljar's Avatar
Re: Opti Delete
I wasnt sure exactly what you were asking for, the intake manifold swap i did or the distributor, because they both went along with the post.
The distributor works great in all conditions. A+
The setup as a whole is hard to judge how its running because it just spins, and spining isnt any faster than the next person spinning.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
tnmotown
Aug 10, 2015 11:52 PM
asilomar244
Jul 12, 2015 05:53 AM
