Opti convervsion q
Old Mar 15, 2004 | 01:13 PM
LilJayV10's Avatar
Opti convervsion q
I am doing the opti conversion on the 93Z that I am building. Originally I ordered the cam for a 93, what I didn't know at the time was you can't do the CSI/double roller conversion on a non vented opti because of the fact the opti is driven off the back of the cam gear. Now I am doing the opti conversion and am going to have to get a cam for a vented opti.
I have the webpage that shows the differences between the two cams but I still have a few questions.
How is the opt driven in a vented opti? Is is with the longer dowel pin or is it the splined hole in the cam or both?
I talked to brent today at TEA and asked him and he said it was driven off the dowl pin only. I think I caught him at a bad time because he wasn't makint much sense.
Thanks for any help.
Jason
Old Mar 15, 2004 | 01:17 PM
There is no "spline" in the cam gear for the vented Opti. It is just a pilot hole. The Opti is driven only by the dowel pin.
Old Mar 15, 2004 | 02:21 PM
speedmiser's Avatar
Besides the dowel pin drive, The vented opti does have an oring'd shaft that protrudes through the timing gear and into a hole in the center of the face of the cam. It's really not part of the drive - I suppose you'd say it's a locator...
Anyway, Most aftermarket LT1 cams have the larger hole in the center, so they'll work with vented or non-vented setups (although you'll still need the correct dowel pin).
IMO - It would be worth your time to check and make sure your cam has the correct size hole in the face to work with the vented opti.
Old Mar 15, 2004 | 06:15 PM
LilJayV10's Avatar
Thanks for the replies. It makes sense now. I miss read.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
