opti conversion question
Old Oct 18, 2006 | 06:22 PM
ajlew9428's Avatar
Im going to convert to a 95+ opti. If I do this, will I need a new cam as well?
Also, the guy selling the kit, said the Lt4 HD DR timing chain was crap. He said he could show me numerous sprockets that were stripped. Has anyone had a bad experience with this chain?
Old Oct 18, 2006 | 07:07 PM
Mtrhds94Z's Avatar
Re: opti conversion question
Yes, you have to chagne the cam..
Old Oct 18, 2006 | 11:09 PM
Opti swap details, with part #s:
http://para.noid.org/~muttvette/opti.html
The reports of failed LT4 Extreme Duty timing sets that I have seen seem to point to incorrect install procedures. I've been running the ED set for 6 years in an 800HP nitrous motor with a solid roller cam and beefy valve springs, and no problems. A buddy of mine made over 1,100HP in a 383 with 20+# of boost and a solid roller, and no problems with the ED set.
Old Oct 18, 2006 | 11:55 PM
ajlew9428's Avatar
thanks. A company on ebay has a kit with all this in it for like $500. its like $750 w/ Lt4 hotcam.could I just use the stock setup with the kit? would it not be reliable? Im getting Lt4 hotcam kit as well
Old Oct 19, 2006 | 11:56 AM
Why do you feel you need an Extreme Duty timing set? The stocker isn't all that bad for a bolt-on setup, and there is also an LT4 (standard duty) timing set, with a heavier cam sprocket to compensate for some harmonics in the LT4 cam/valve train. I machined away some of the bulk in the LT4 ED cam sprocket, since it is way heavier than it needs to be.
Old Oct 19, 2006 | 04:30 PM
ajlew9428's Avatar
I just wasnt sure if it was agood idea to do while im changing out the cam. thanks
Old Oct 19, 2006 | 06:31 PM
wicked_95z's Avatar
I too have run the LT4 Ed timing set with no problems to 6800
I wouldnt recommend with the hotcam kit. Do a little research and you will find out you can get more power with less or about the same money. Just my .02
Old Oct 19, 2006 | 11:06 PM
kingslam's Avatar
hey go to Summit Racing, and look at the MSD and Accell OPTI replacement, they have vented 94 OPTI's that are cheaper and better than doing an E-Bay conversion!
Old Oct 20, 2006 | 11:09 AM
ajlew9428's Avatar
Do you mean this kit comes w/ just the opti, and it fits the 94 dowel, but is vented? The kit on ebay comes with a new 95 gm opti, timing cover, timing chain, sprockets, gaskets, and is 0nly $550. I cant find what you are talking about on summit, but assume it is over $500.
Old Oct 20, 2006 | 11:49 AM
If you are going to do a cam anyway, it is a good time to convert to the vented opti. Converting also give you more timing set options.
The flip side is the MSD opti that fits your current splined drive has a complete vent system (which the normal splined opti does not have) and you don't have to change anything else. You can use any cam you want, but still have to use the stock type cam gear with the splines in it.
Old Oct 20, 2006 | 12:13 PM
ajlew9428's Avatar
Ok, I get it. Since im putting in the lt4 kit, do you think I should just get the 95 conversion kit anyway? Comes with timing chain, cover gaskets, vented opti. Its just a couple less things I will have to worry about in the future.
Old Oct 20, 2006 | 04:04 PM
I would have to see this "kit" to comment about it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
