Opti Bad??
Old Nov 14, 2003 | 06:28 PM
2Fast94TA's Avatar
Opti Bad??
i just bought a 94 TA and at full throttle around 4500+ rpms the engine hesitates. i took it back to the dealer and the engine was throwing no codes. could it be a bad opti spark, how would you test it?
Old Nov 14, 2003 | 06:44 PM
JDBlaze85's Avatar
before you replace anything major like an opti...........
1.if you can.......monitor your 02 sensors at 4500+ wide open throttle in drive
2.check fuel pressure
3.inspect wires and plugs.....if they look old, I would replace them first before moving forward.
theres more sensors to check and MAYBE the opti can be going bad but check those above first.
Old Nov 14, 2003 | 08:36 PM
2Fast94TA's Avatar
well the car is still under a used car warrenty from the dealership, so im not sure what to do. seems that they will only fix what the codes tell them to, but its not throwing codes.
Old Nov 14, 2003 | 08:44 PM
JDBlaze85's Avatar
if its under warranty.......just give them your complaint. they should fix it. let them drive it so they can see its not right. the pcm cant figure out every problem.
Old Nov 17, 2003 | 05:02 PM
2Fast94TA's Avatar
well doesnt seem like they want to fix it, because it only happens under full throttle and who drives that way in a Trans Am anyway?? so how can i go about finding it out for myself?
Old Nov 17, 2003 | 05:14 PM
JDBlaze85's Avatar
the trans am was meant to be driven full throttle.
mustangs/imports - naw
anywayz..........scroll up, and you will find one of my old posts as to where you can start on getting the car running better. post#2
check all that out and post back what you found. later
Old Nov 20, 2003 | 08:51 PM
2Fast94TA's Avatar
thanks, i have now fixed the problem. i changed the original fuel filter and ran a fuel system cleaner.
Old Nov 20, 2003 | 09:47 PM
JDBlaze85's Avatar
Old Nov 22, 2003 | 12:34 AM
2Fast94TA's Avatar
welp spoke too soon, took her out today and sure enough the problem is still there. seem to be in the fuel delivery what else could it be?? i also have noticed that after i switched to synthtic oil that it leaks like crazy i have a tilted driveway and i must have a spot as big as a notebook on the driveway.
Old Nov 22, 2003 | 12:37 AM
2Fast94TA's Avatar
also it seems to happen later now, 5000+ rpms its weird
Old Nov 22, 2003 | 01:08 AM
Blu85ROC's Avatar
I think you should check everything else out first but, I had the same problem and when I changed my opti it went away.... major pain and serious drain on wallet. Hope it helps.
Daniel
Old Nov 22, 2003 | 01:52 AM
97WS6SCharged's Avatar
Yeah, synthetic is much more slippery than the conventional dino leftovers. So while it does lube better, it is also better at finding weak seals and gaskets and finding its way out of the motor.
As far as your ignition stumble, check all the plugs and wires as was mentioned earlier. These are somewhat easier to change than the Opti. If that doesn't fix it, go ahead and get a new Opti and do the vented cap conversion and if the car is getting close to 100K miles, look into getting a new water pump.
Old Nov 22, 2003 | 12:32 PM
2Fast94TA's Avatar
nope only has 59k on it , but thanks ill get new plugs and wires. i just thought it had something to do with the fuel delivery.
HectorM52
Jul 30, 2017 11:46 AM
beltrunner
May 17, 2015 10:18 PM
BLK1997Z28
May 7, 2015 03:01 PM
Noenav
Apr 30, 2015 01:06 PM
ad356
Apr 11, 2015 10:30 PM
