Which Opti
Which Opti
Ok my car is driving and running poor under hard acceleration. I have concluded that it is the opti spark. I have a 1994 z28 camaro i was wondering if i needed the vented or non vented. And how long does it take to replace. Also where can i buy one of these on line. And are there any other parts i need like new gaskets or what not thank you ,
~$300 for a new GM non-vented optispark.
Either of these guys can supply what you need:
Dal Slabaugh: 877-448-5451
email: lockitup@bright.net
VanDevere Buick/Pontiac/Olds Akron, OH
or
Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept ph #)
email: gmparts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
I hope you have ruled out plugs and wires first.
or
http://www.corvettefever.com/howto/16758/
I would recommend you look into doing this. Its what I plan on doing when I replace my non vented opti soon. You can practice on your old opti so you don't mess up the new one. This will be cheaper than going vented, and I have heard it is just as good. Good luck.
The suggestion I offered still requires you to replace the opti. What it does is make a non vented opti spark vented, which gives you the benefits of a vented opti, without having to pay the extra costs to convert.
I have heard this is the way to go, but I haven't used it. I have read many threads on this subject and this seems to be one of the best I've seen. Hope this helps....
http://www.dynotech-eng.com/dynaspark.htm
They don't go out that much to make me wanna pay $600 for one. Not to mention when mine does go out, LIFETIME FREE REPLACEMENT WARRANTY at autozone Thread
Formula Steve
Sep 19, 2023 08:31 AM
