Opinions needed on Water Pump Seal - pics inside
Old Jul 1, 2007 | 11:15 AM
scottso's Avatar
After opti and water pump install, had to tear down again cause I had an oil leak. The seal was definitiely damaged during install (don't know how I did that). Does this look sufficient to cause a leak? We are talking about probably a couple of dozen drips after a drive.
Old Jul 1, 2007 | 11:48 AM
I would replace that seal. It's chewed up.
Old Jul 1, 2007 | 11:49 AM
JP95ZM6's Avatar
Yes, that is definately enough damage to wreck the seal. The 'lip' at the front is the part that actually seals, and needs to be intact all the way around the shaft.
Old Jul 1, 2007 | 11:54 AM
hotrod18_69's Avatar
Yes, replace it for sure..
Old Jul 1, 2007 | 11:58 AM
wrd1972's Avatar
Most likely installed incorrectly or not lubed, There is a reeason. Replace it NOW.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
