opinions on hooker super comp shortie headers
Old Apr 25, 2004 | 09:13 AM
kingman109's Avatar
well i have a 97 camaro that was totaled and i rebuilt - needs to go through inspection but my exhuast manifold is cracked. so i was thinking abuot picking up a set of hooker super comp shortie headers ceramic coated. to bolt in place
these
hows the quality on these and anyone have any better suggestions?
Old Apr 25, 2004 | 09:54 AM
Bud M's Avatar
They are single cat headers for 93-95 so you will have to convert to single cat or no cat at all.
They are ok headers if you need a CARB E. O. number, otherwise there are better headers out there, like AS&Ms or longtubes.
Quality wise the headers are fine but the fit on my y pipe should have been better, it needed modification to fit properly.
Old Apr 25, 2004 | 01:16 PM
kingman109's Avatar
umm u sure - 1995-97 Camaro Z/28, Pontiac Firebird Formula/Trans Am, LT1 350 w/Dual Catalytic Converters - and reason staying away from longtubes and such is cause i have to go through a salvage inspection. they wont allow longtubes to go through so i need a set of shorties that will essentially hook up to y-pipe with slight modification ..
anyone reccomend any others?
Old Apr 25, 2004 | 07:41 PM
GREENFBIRD's Avatar
I HAVE A 97 FIREBIRD LT1 AND I JUST BOUGHT SET OF HOOKER SHORTIES THEY BOLT UP YOU JUST HAVE TO CUT FLANGE AND REPLACE ITH THERE ON PASS. SIDE
Old Apr 25, 2004 | 08:28 PM
gb95zconv's Avatar
The collectors are very restrictive....the opening isnt much bigger than the stock manifolds. If you open them up about 1/4" all the way around with a die grinder you will see better gains.
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jason Short
Jan 19, 2015 06:34 PM
Killer94z
Jan 13, 2015 12:06 PM
guyomatic
Sep 11, 2002 02:11 AM
twistedwedge
Jul 27, 2002 01:54 PM
