Opinions on comp cams 986 springs please!!
Old Mar 5, 2007 | 06:38 PM
arklie's Avatar
Hey everyone,
Questions about comp cams 986 springs.
I'm just wondering what is the max lift on these springs.
Will they work with the LT1 heads without modification?
I'm planning on doing a 1.6 RR upgrade now and then a cam (possible cc305) in the future. Will they work for this?
Anyone run this cam and have opinions about it?
Thanks alot.
Old Mar 5, 2007 | 08:31 PM
SStrokerAce's Avatar
They will work for the rocker upgrade but don't work well on cams, even though they are recomended on the Comp shelf stuff. A set of beehives will work well now and later.
Bret
Old Mar 6, 2007 | 06:05 PM
fireman's Avatar
I have run the 986s with my CC306/1.6rr combo for years and they work great.
Old Mar 7, 2007 | 10:37 AM
Z-RATED94's Avatar
Fireman, no offense, I just find it hard to believe those springs are enough for that cam. There is more to a cam than I claim to know about, but the basic specs of mine are a much smaller than yours and I found the 987's not tobe enough spring. Granted my lobes might be more aggressive, but still, I don't know why yours work for you. Anyways the 918's solved my problem.
Old Mar 7, 2007 | 11:35 AM
fireman's Avatar
Comp recommended the 986s and I got 'em. I run Crane gold 1.6rrs and the CC306. Also run Type R lifters, 12:1 compression and LT4 valves in unported castings. I make peak HP at 6200rpm. I can email you a dyno graph if you would like.
Old Mar 7, 2007 | 12:06 PM
Z-RATED94's Avatar
Please do, if you don't mind. Maybe the light weight valves have something to do with it? Thanks, Rick.
Old Mar 7, 2007 | 01:08 PM
Yeah that's the only way they work is with the lightweight LT4 valves.
Bret
Old Mar 7, 2007 | 01:49 PM
fireman's Avatar
They are actually Manley Raceflo valves, just in LT4 sizes. Don't know what they weigh in comparison to the actual LT4s.
Old Mar 7, 2007 | 02:23 PM
fireman's Avatar
Just sent the dyno file to the email in your profile Zrated.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
