open loop runs fine, closed doesnt...
In closed loop the car surges, bucks jerks, etc... Put new O2's in it with no affect.. So I had PCMforless (bryan) give me a pcm with a open loop only provision, car runs good now, we think it is breaks in the wiring from pcm to O2 sensor (s). Has anyone had this problem or similiar? Where do I start to try to find the break in the wiring etc, Scanner shows the sensors as working fine though.
the only way to keep your car in open loop w/o programming is unhooking an O2 sensor.
the wires for the O2 sensors are very easy to follow so you should be able to see if theres a problem in the harness. now if you hook up a scanner you could actually observe them to see if the pcm is reading the sensors correctly.. that would rule out wiring issues. what youd then check are your BLMs to see if theres any signs of an exhaust leak.
what mods do you have and what yr is your car?
supercharged94Z28
Feb 24, 2003 10:22 PM
